Grinding Gears.
Old Dec 12, 2008 | 10:31 PM
Tylercore's Avatar
Default Grinding Gears.
I have a 1998 300EX. It has been running fine, but I recently noticed that in 2nd gear, if I hit the gas to spin the tires, the gears make an awful grinding noise. Has this happened to anyone else? Do you have any suggestions of what to do?
Old Dec 12, 2008 | 10:52 PM
Gimpster's Avatar
After making sure it is not a rear axle bearing, the engine may need removing and the gears and bearings on the transmission need to be inspected. If one end of the main or countershaft goes out, the shaft will be allowed to let the gears not mess totally in some gears. An inner gear sleeve could have worn out or the inner gear mesh teeth can be damaged. One more thing... Bent shift fork.
Reguardless the engine will need be split
----- Gimpster -----
Old Nov 16, 2019 | 10:37 PM
Ryan Reckart's Avatar
Default 2nd and 3rd gear grinding how hard is it to split the case and do gears and shift for
Can I do it or pay someone to fix it I work on all of my cars trucks?
Old Nov 17, 2019 | 02:17 AM
"Can I do it"
Only you can answer that. If you would/could strip a car or truck gearbox, then no problem, the bike box is not quite as complex. If not, then maybe you should get a motorcycle or Quad mechanic to do it.
mudder234
ATC 3-Wheelers
Nov 21, 2007 05:54 PM
shrk6602001
Dec 31, 2005 03:52 AM
PipedBanshee
Dec 5, 2004 08:49 PM
machman
Jun 3, 2003 04:26 AM
WreckRaptor660R
Dec 2, 2001 09:06 PM
