04 700 efi running issue
I have a 04 700efi sportsman, it idiols fine fuel pressure is 40psi, when i give it some gas it dieds? ANY help would be great. fuel filter is new and installed in the right direction.
Sendori THANK YOU for the etc idea. I solved the problem, it was etc related. I motor is going into abuggy i am building so the wire harness is layed out. I had 2 sets of brw and blk wires that when connect or dis connected allowed the motor to idiol, but both sets need to be disconnected for the motor to run above idiol.
THANK YOU VERY MUCH FOR THE ETC SUGGESTION, i have beenworking this issue for a week.
