04 700 efi running issue
Old Dec 13, 2008 | 03:59 PM
jerrymi's Avatar
Default 04 700 efi running issue
I have a 04 700efi sportsman, it idiols fine fuel pressure is 40psi, when i give it some gas it dieds? ANY help would be great. fuel filter is new and installed in the right direction.
Old Dec 13, 2008 | 07:56 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
does it die or just running crappy. does it start right back up? is the etc set right and have about 1/8" play?
Old Dec 13, 2008 | 08:21 PM
jerrymi's Avatar
It just dies, it does start right back up, I need not ck the etc. it idiols at 1110 i can very slowly get it to 1260 then it dies
Old Dec 13, 2008 | 08:27 PM
jerrymi's Avatar
I do not have the etc unit i just have the cable going to the throttle body, when i try to idiol it up by pulling on the cable end it dies
Old Dec 13, 2008 | 09:28 PM
jerrymi's Avatar
Sendori THANK YOU for the etc idea. I solved the problem, it was etc related. I motor is going into abuggy i am building so the wire harness is layed out. I had 2 sets of brw and blk wires that when connect or dis connected allowed the motor to idiol, but both sets need to be disconnected for the motor to run above idiol.
THANK YOU VERY MUCH FOR THE ETC SUGGESTION, i have beenworking this issue for a week.
chinkapin
Jul 14, 2016 06:58 AM
BEEFKING69
Jun 17, 2015 12:38 AM
robj
Jun 15, 2015 08:45 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
Steven Bandemer
May 27, 2015 07:39 PM
