199 timberwolf
Old Dec 14, 2008 | 07:33 AM
cchucky51's Avatar
Default 199 timberwolf
got a 99 timberwolf
got a problem wtih it bogging down when you hit the throttle i have cleand air filter ran some carb cleaner?
i notice that if you let off the throttle and then hit it! the engine will backfire throught the carb?
any ideas as to where to look?
adjust?
any thing ?
Old Dec 14, 2008 | 03:45 PM
91Warrior357's Avatar
its most likely got some crap inside the carb and needs to be taken completely apart and cleaned real good.
Old Dec 16, 2008 | 12:19 AM
cadillacdude1975's Avatar
run some seafoam through it. that might clear it up without having to disassemble any parts.
Old Dec 16, 2008 | 01:51 PM
gotanswers's Avatar
you problem is carb! 1 of 2 things wrong. (1) carb dirty staving for fuel (2) your air and fuel screw (pilot screw) is out of adjustment.its a brass screw on bottom of carb turn it tell it stops but dont force it back off 2 3/4 to 3 turns out that should be right.another hint if its poping thats a sign of loading up which means to much fuel stand behind bike while ideling does it burn your eyes out or smell rich if so then its to rich and its you pilot screw out of adjustment
Old Dec 17, 2008 | 07:28 AM
goto bikebandit.com, use the tool to select your year make and model then click aftermarket parts. choose fuel/air and it will list all the carbs new for that make and model. my carb is 95 bucks brand new. i will be getting one of these units with the tax return.
wildbill59
Jun 22, 2015 09:22 AM
wildbill59
Jun 9, 2015 02:28 AM
atc350
Jun 27, 2000 11:48 AM
95TimberWolf
Mar 14, 2000 10:33 AM
Brian_Kimmel
Aug 9, 1999 02:24 PM
