electrical woes
Old Dec 14, 2008 | 10:01 PM
McKay5858's Avatar
Default electrical woes
I have two seperate issues. First one is everytime i hit the front brake i blow the main fuse. I dont see any obvious barespots on the wire but i havnt dug really deep yet. Could this be the brake light maybe? Also my fan quit. I have power at the connector but my ground doesnt test. One wire has the power, the other wire i tested by clamping my test light on positive side of the battery and touching the wire, no light. I am not an expert with this stuff but i know the basics. Any help would be great thanks.
Old Dec 15, 2008 | 11:53 PM
McKay5858's Avatar
i was foolin around with it tonight, my fuse blowing was because i got moisture in the tail light. i figured my fan out, i'm gettin power there now but the fan doesnt always come on when theres power there. Sometimes i have to give the fins a little push then it takes off. is this normal? is there anyway to take these fans apart and lube them up or something
Old Dec 16, 2008 | 02:45 AM
MRDS650's Avatar
Canadian and Proud of it !!!
I think your fan is done - a commen problem in the olders Ds's. I have went threw about 5 myself over the years. Last one I bought aftermarket and it has lasted a couple of years now.
I think the really reason is I changed how it mounts. I installed a couple of flat pieces of metal accross the rad supports and bolted the fan to those pieces. I think the old way the fan can be distorted and can cause the fan motor to fail early.
The last I bought a fan it came from jaycorp technologies part #30100402. Only thing you will have to do is cut the old connector off and re-soder it onto the new wires on the new fan. I paid about 60 bucks a few years ago.
Hope this helps
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
