Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
gas problem
Old Dec 16, 2008 | 08:23 PM
happyhunter's Avatar
Default gas problem
I have 330 outlander,the bike will run 15-20 mins then quit,will run awile with choke on then quit,just like it is starving for fuel,leave sit 30 mins it will go again and it will do it all over,to carb apart everything seems fine bit of dirt,seems like it gets hot but its not coil,checked lines,now i will try fuel pump now last resort than payn big $$$$$ service tec. Also try fuel cap for blockage. Does anyone have any help for my problem, Any help,be very grateful, thank u happyhunter
Old Dec 16, 2008 | 10:02 PM
Doctorturbo's Avatar
GOT BOOST!
Default gas problem
Sometimes these things are a vent problem. Check the gas cap vent and all carb vents.
The next thing I would check is to make sure your gas "flow" to the carb is good.
Old Dec 17, 2008 | 08:36 PM
Default gas problem
gas flow is good ,checked hose from air breather to carb,plugged it with finger and it ran with choke on ,took it off and die, did that couple times , no it seems to be different not so much suction , then it cleared up,now it runs again ,for how long i dont no,knock on wood,maybe there was dirt or obstruction there,now u mentioned air prob that sounds like problem starving for somthin. I am grateful for your help and if problems persist will dig deeper. Thanks again doctorturbo.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
