1985 Fourtrax 250 carb question
Old Dec 19, 2008 | 11:10 AM
goozyman's Avatar
Default 1985 Fourtrax 250 carb question
Hello all.
I just got a pretty decent Fourtrax 250 [2WD]
The guy that sold it said the carb is dirty and it needed a little tap on the carb with a screwdriver to get er started,
I am in the process of taking the carb off to give it a good cleaning, but ran into a snag.
I have it all off but the throttle cable is somehow still attached to something inside the carb [i unscrewed its housing from the top of the carb, but the cable still goes to somethign inside..]
any ideas how to get this cable out? or does it even come out easily?
Old Dec 19, 2008 | 11:49 AM
johnboy27's Avatar
is there a side cover? if there is take it off and you will see the cable end and the linkage. iv never worked on one of these so im not sure what style carb you have.
Old Dec 19, 2008 | 12:04 PM
goozyman's Avatar
thanks for the reply.
This is what the carb looks like, im not sure if its a side plate or not. im new to all this [img]i/expressions/face-icon-small-smile.gif[/img]
http://cgi.ebay.com/ebaymotors...5fPartsQ5fAccessories
it is ebay item 140288684798
Old Dec 19, 2008 | 12:24 PM
johnboy27's Avatar
yea that black plastic cover comes off and you will see where to unhook the cable
Old Dec 19, 2008 | 12:26 PM
goozyman's Avatar
if i "unhook" the cable, is there a setting or measurement i need to take? or will the cable "hook back on" with the same adjustment it came off as?
sorry if this seems like a dumb question but ive never done this before
thanks
Rich
Old Dec 19, 2008 | 12:51 PM
johnboy27's Avatar
it will be the same, unless you mess around with the idle ****. once you take the cover off you'll get a good idea how everything works.
Old Dec 19, 2008 | 12:59 PM
goozyman's Avatar
thanks so much for your help, ill post the results [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 22, 2008 | 08:45 AM
goozyman's Avatar
Hi Johnboy, just wanted to check in and let you know all went well with the carb surgery project [img]i/expressions/face-icon-small-smile.gif[/img]
I took the black plastic cover off the side of the carb and there was a connector almost like a hand brake on a mountain bike [little lead drum sliding into a hole]
I sprayed er all down with carb cleaner, cleaned the funk out of it , put er all back together on the bike and it worked.
thanks again
Jmuddin284
Jan 19, 2026 07:16 AM
tweeder
Jul 5, 2015 01:57 PM
yambam13
Jul 4, 2015 01:49 PM
Mikea1978
Jul 4, 2015 12:37 PM
D-Hagz
Jul 4, 2015 02:19 AM
