1994 Kawasaki Mojave 250 Wont Start
there are several reasons why an ATV wont start after a bath
1. water in the carb.(drain the carb bowl, and refill with fresh gas)
2 spark plug is wet, or connection between plug an boot is weak. ( take some dielectric grease and squirt it into the plug boot. then put it on thre plug.) this will keep a good contact between the plug and boot.
remember an engine needs 3 things to run: spark, compression, and proper fuel/air mix. check the spark. drain the carb and fill with fresh-unwatred gass-from the gas tank. and if it runs when dry you obviously have compression.
just good things to keep in mind
good luck!
good luck!
