2005 TRX450R Engine Problem
I have a 2005 TRX450R with a k&n airfilter, a pro circuit slip on exhaust, and the honda hrc kit. When I run the bike it sounds great at idle and reving, however when accelerating the bike begins to stutter when it hits the high rpm's. Any advice at what could be wrong? Ive changed the spark plug, changed the oil and filter, and also clean the air filter but still no luck.
If it is fine in the low and mid ranges....sounds like your jetting just isn't quite perfect on top. This would be your main jet. A different shaped needle can help sometimes as well, but the needle position is probably correct.
<div class="FTQUOTE"><begin quote>Originally posted by: reconranger
Pull out the jet that's in there, and see what size it is. Jets are cheap, so get one a size bigger and one size smaller, and try those.</end quote></div>
hoopduerr
Jun 1, 2015 08:22 PM
