2005 TRX450R Engine Problem
Old Dec 25, 2008 | 01:39 AM
glamisman7's Avatar
Default 2005 TRX450R Engine Problem
I have a 2005 TRX450R with a k&n airfilter, a pro circuit slip on exhaust, and the honda hrc kit. When I run the bike it sounds great at idle and reving, however when accelerating the bike begins to stutter when it hits the high rpm's. Any advice at what could be wrong? Ive changed the spark plug, changed the oil and filter, and also clean the air filter but still no luck.
Old Dec 25, 2008 | 09:30 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
If it is fine in the low and mid ranges....sounds like your jetting just isn't quite perfect on top. This would be your main jet. A different shaped needle can help sometimes as well, but the needle position is probably correct.
Old Dec 25, 2008 | 01:15 PM
glamisman7's Avatar
Thanks for the tip. would you recommend any size jet?
Old Dec 25, 2008 | 02:57 PM
Red Rider
Pull out the jet that's in there, and see what size it is. Jets are cheap, so get one a size bigger and a size smaller, and try those.
Old Dec 25, 2008 | 05:47 PM
nottelybill's Avatar
I use to have a Honda motorcycle that would do that and it was the spark plugs. They looked like they were new but change them and the problem went away. Just a thought.
Old Dec 26, 2008 | 03:12 AM
glamisman7's Avatar
ya i already did that and changed the oil and cleaned the entire carb. does anyone have any suggestions on what size jet i should run? it has a 185 in it already.
Old Dec 26, 2008 | 10:27 AM
Red Rider
<div class="FTQUOTE"><begin quote>Originally posted by: reconranger
Pull out the jet that's in there, and see what size it is. Jets are cheap, so get one a size bigger and one size smaller, and try those.</end quote></div>
neilbedwell
Nov 10, 2018 11:02 AM
Land_shark1
Jul 10, 2015 12:53 AM
dorene
Jun 5, 2015 05:25 PM
hoopduerr
Jun 1, 2015 08:22 PM
kevbowe
Jun 1, 2015 01:17 AM
