Missing Hose!
Old Dec 30, 2008 | 07:10 PM
hal9er's Avatar
Default Missing Hose!
I have a 1980 Honda 110 atc. There is a male port by the idle adj screw and in all the pictures I see there is a hose attatched to it. I cannot find out where the hose connects to on the other end!! Any info would be appreciated. Thanks!
Old Dec 31, 2008 | 02:23 AM
Williebee's Avatar
hal9er i don't have an O.E.M. factory manual however i do have a INTERTEC Service and Repair Shop Manual , but it only cover's the 1984 Honda ATC 110 and it doesn't go into real detailed pic's showing where the line's are ; i can see that there are 2 hose's that come from the fuel/petcock and hook to the carb one is for the main on valve and ther other is for the reserve at least !
All the other hose's are just vacume lines if the male port is on the carb itself it maybe the drain tube that for fuel to leak out the over flow that leak's when the inlet needl valve leak's when the float stick's , if not it could a hose that goes to the air box but it's only a vent tube ; i could help more as well as other's the forums if you could take some pic's so we could geta look at the place where the fitting you're talking about !
And welcome to the forums !........
Old Jan 1, 2009 | 06:54 PM
hal9er's Avatar
I will get a pic on here! Thanks!
Old Jan 1, 2009 | 07:01 PM
hal9er's Avatar
3 Wheeler
Old Jan 4, 2009 | 08:12 PM
pauley501's Avatar
the other end of the hose just hangs its only a vent.
Old Jan 5, 2009 | 01:52 PM
hal9er's Avatar
thanks!
95wolv
Sep 27, 2024 12:00 PM
Sassinm1
Sep 30, 2015 04:23 AM
panicmanic
Sep 28, 2015 12:59 PM
tysonbully
Sep 28, 2015 02:30 AM
bigred20653
Sep 19, 2015 02:11 PM
