Mojave Clutch Replacement
Old Dec 31, 2008 | 12:10 PM
Kernalklink's Avatar
Default Mojave Clutch Replacement
is replacing the clutch pack on a 01' Mojave a very tricky job - i have a new DP clutch kit ready for installation just haven't ever done one. also any suggestions for other replacements while the machine is apart would be helpful.
Old Dec 31, 2008 | 08:08 PM
Honda777's Avatar
As far as I know your Mojave clutch should be very straight foward just be sure to pay attention when you take it apart and put it back together the same way. Somtimes the jobs you dread are the easyest.
Old Jan 1, 2009 | 01:32 AM
jeffeosso's Avatar
got a service manual AND a set of gaskets?
no, REaLLY, its an easy job, but you need said manual and set of gaskets
Old Jan 1, 2009 | 05:29 AM
smitty800's Avatar
im 15 and i just installed a new dp clutch i did it without a manual but it took alot time because i didnt know how tight the clutch spring bolts should be and i took some stuff all the way apart that didnt need to be. i know now how to do it because ive had it apart so many times re doing what i messed up on. i would most definently get a shop manual for it. its like 60 bucks and will save you alot of time.
Old Jan 2, 2009 | 09:11 AM
<div class="FTQUOTE"><begin quote>Originally posted by: smitty800
i just installed a new dp clutch</end quote></div>
did you notice a big difference? my clutch is working ok now but i have the DP kit so i might as well install it. but i just wonder what you think about it?
Old Jan 2, 2009 | 09:18 PM
smitty800's Avatar
i noticed a big difference. as soon as you let the clutch out it is grabing. when im on it in a drag it pops the front tires off the groud in second and third a little. the only thing i dont like is how hard it is to pull the clutch in. its pretty stiff but i just bought an eZ pull clutch lever so hopefully that will fix the problem. you did get the whole kit springs and all correct?
Old Jan 2, 2009 | 09:20 PM
smitty800's Avatar
and it does all of that with out the pipe and jet kit on it because i have not yet installed them yet.
Old Jan 8, 2009 | 05:27 PM
yea, i have the whole kit springs and all - hopefully i will get it installed in the next couple of weeks
I have to stand on the grab bar to get it to pop a wheelie -
i will let everyone knows how it goes installing it
ghost civic
Jan 15, 2020 07:43 AM
clsharky
Jul 13, 2015 02:07 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
coolguy420
Jul 10, 2015 01:17 AM
