2002 Honda Rancher ES shifting problem
Old Dec 31, 2008 | 01:04 PM
JoeKrz's Avatar
Default 2002 Honda Rancher ES shifting problem
After about 10 minutes of warming up the ES controls quit working. I can shift for the first 10 minutes or so and then POOF it quits working. Any ideas what to look for?
Old Jan 1, 2009 | 05:22 PM
ElBando's Avatar
I have a ESP shift problem also, maybe no one is replying because there are so many threads on this . Do a search and you will find info on the ESP. I have a thread about it and I think it is a bad angle sensor ( in my case ). You may have a problem with another sensor, or low voltage , or a bad wire/connector, etc.
Old Jan 1, 2009 | 07:44 PM
dgratvbikeshop's Avatar
Hello, try the ground wire next to the right front wheel under the front fender there is a black box that has main ground hook up make sure it is clean and tight.
Old Jan 1, 2009 | 09:58 PM
JeffinTD's Avatar
Is it snowy/icy there? Maybe in the 10 minute warm up, something got wet?
It might be worth while taking apart every connector on the machine to spray them out with contact cleaner, blow dry with an air compressor, and pack with diaelectric grease... Even if it doesn't solve the problem, doing so seems to prevent little electrical gremlins.
Old Jan 2, 2009 | 08:42 AM
JoeKrz's Avatar
Well I have had it through some ice, snow and rain lately. I ended up unplugging the angle sensor, spraying some WD-40 all over the plug connectins and then plugging it back in. Everything works fine now. Thanks for the tips.
Old Jan 5, 2011 | 06:51 PM
reeseharbersonn's Avatar
Default 2002 Rancher ES shift problem
I also have a problem shifting, when i shift up it does great but when i down shift i have to press the button four or five times. When i press the button it makes a noise but doesnt go into gear.
neilbedwell
Nov 10, 2018 11:02 AM
ROWALKER
Jun 15, 2015 05:38 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
aby11
May 7, 2000 07:58 PM
Rancheres4X4
May 5, 2000 02:09 AM
