Oiling versus Grease in the front hubs....
Old Jan 14, 2009 | 12:39 PM
jjump's Avatar
Default Oiling versus Grease in the front hubs....
So I know that the front hubs need oil in them, not grease on the bearings and the Hilliard.
My question is though, and the manual doesn't clarify, do the first 2 bearings that are in the "strut" need greased?
It seems that the seal on the hub that goes on the outside of the coil would contain the oil to the hub only.
Am I wrong for thining this, and therefore I would need to grease the 2 strut bearings??
Thx
JJ in Pittsburgh
2001 Scrambler
2007 Sportsman
Old Jan 14, 2009 | 01:12 PM
jjump's Avatar
Also, on top of that, I learned from the Dealer that there is regular grease, and u-joint grease....
Is the u-joint in this case the CV joint?? or are all 3 different and require different lubes??
Thx....
Old Jan 14, 2009 | 01:45 PM
Demand drive hub fluid in hubs only,it lubricates the 2 strut bearings,hilliard and 2 hub bearings! NO grease on bearings,it will mess up awd action. Yes there is u-joint grease,BUT its mostly lithium based and use can use any good lithium based grease for all grease fittings. U-joints deping on model have grease fittings,cv joints have grease inside protected by the rubber boot.
lightninboy
May 16, 2021 09:52 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
traumajunkie
Jul 5, 2015 03:03 PM
ranvette
Jul 4, 2015 06:13 PM
Shifts
Jul 3, 2015 07:59 AM
