new carb white smoke?
Old Jan 19, 2009 | 07:53 AM
hondaman300ex's Avatar
Default new carb white smoke?
just put a new motor on my honda 110 and a new aftermarket carb. cranked fine but had lots of white smoke then died and will not crank .i checked my spark and i have and orange spark now can anyone tell what the hey is wrong?
Old Jan 19, 2009 | 09:27 AM
brian 68's Avatar
what do you mean new motor , newly rebuilt or new used, either way has the motor set for a while , you may have rolled it around and oil leaked into the cylinder , if your lucky, but if it won't crank over you may have broke your rings , bound up in the jug , ect . pull the plug and change it look into the plug hole , check the oil for metal
Old Jan 19, 2009 | 09:34 AM
brian 68's Avatar
the reason i ask about the motor , there are alot of people that think new ring's is rebuilt, when in fact the jug needed bored , new ring in a worn cylinder would act exactly the same, smoke , run who know's how long , seize up. also a bad head gasket will cause smoke. but it should turn over. seem's like you'r project is just getting started. good luck
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
tweeder
Jul 5, 2015 01:57 PM
