Sportsman 500 - No Spark!
Old Jan 22, 2009 | 06:10 PM
W2LHM's Avatar
Default Sportsman 500 - No Spark!
I have no spark on my 2002 Polaris Sportsman 500. The problem started when I had to remove the head, including the pull start, flywheel and stator, to replace the tensioner on the timing chain. When I got everything back together I had no spark.
I'd read about others who had a squashed spark plug cable from it being run between the fuel tank and the frame, and since mine had a flat spot on it from that same situation, I replaced my coil and plug wire combination. And I got my spark back . . . for a minute. By the time I got the plug back in the engine, no spark again.
My tests with the ohm meter read okay except for two things - the exciter/stator coil test between the red and black/red wires is supposed to be 1.9 ohms, and mine reads 18.5 ohms. And on my new-but-failed ignition coil, the primary resistance is supposed to be 0.3 ohms and mine is 0.7; the secondary resistance is supposed to be 6.3K ohms and mine is 11.5K.
Does anyone familiar with ignitions on these things have any idea what's going on?
Old Jan 26, 2009 | 01:52 PM
W2LHM's Avatar
Just a follow up on this problem, occasionally I do get a single weak spark when I first turn the engine over. But I just get one spark, and then nothing from then on, until I wait 10-15-20 minutes. Then I may get the single spark again.
It's been a few days . . . anyone?
Old Jan 26, 2009 | 04:31 PM
eggenz7's Avatar
try adjusting the trigger coil. dont know about your machine but im assuming it should be pretty close. .015 - .047 is what a 08 500 HO is supposed to be.
Jmuddin284
Jan 19, 2026 07:16 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
Gtsordo
Jul 13, 2015 10:38 PM
Shifts
14
Jul 13, 2015 08:41 AM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
