Kill Switch not working
Old Jan 23, 2009 | 01:51 PM
The original Firehawk's Avatar
Default Kill Switch not working
Hi all!
I need some help troubleshooting the kill switch on my 2002 Sportsman 700.
The problem is when I switch the kill switch on the handle bar to off, the engine does not shut down.
The guages DO turn off, so technically the switch is working?
Any help regarding this would be appreciated!
Thanks in advance for your advice!
Gary
Old Jan 29, 2009 | 05:17 PM
<div class="FTQUOTE"><begin quote>Originally posted by: The original Firehawk
Hi all!
Gary</end quote></div>
I found the culprit !
Thanks for the help...
Old Jan 29, 2009 | 05:44 PM
DCT's Avatar
DCT
Banned
Wow, that was quick. What was it? Broken/loose wire?
Old Jan 30, 2009 | 04:59 PM
I was replacing the headlight bulb in the pod when I noticed a loose brown wire behind the ignition switch in the pod.
The plug going into ignition switch had another brown wire going to it so I used a scotch lok wire connector to splice the broken wire to it. When I did that the kill switch started working again.
Old Jan 30, 2009 | 06:25 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i was going to say to say it sounds like a broken ground wire somewhere.
2x_lung
1) Engine problems..
48
May 24, 2023 05:22 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
bikedad3
Jul 2, 2015 02:15 AM
BEEFKING69
Jun 17, 2015 12:38 AM
vipers
May 31, 2015 09:12 AM
