Chain drive Trailmaster
Old Jan 25, 2009 | 04:11 PM
3cav 84a's Avatar
Default Chain drive Trailmaster
Thanks for the information, another thing came to mind and that was the chain drive to the rear sprocket, there is no diff to speak of so how do you do u-turns or any other type of turn at walking pace. I could understand if you were going quickly enough to slide the atv but at a slow pace how does the thing compensate the need for the outside wheel to go further distance than the inside wheel, regards to all Neil
Old Jan 25, 2009 | 05:36 PM
Fixitlane's Avatar
The inside tire will usually spin a little even at low speed. If it doesn't then you will have to make a larer radius turn. Sometimes you can shift your weight to the outside and get the inside tire to lift a little. Thats how I do my Xpedition, shaft drive but solid axle, just like a chain drive.
Old Jan 26, 2009 | 09:40 AM
Freaksh0w's Avatar
Yeah, just get on the thing and drive it. It will turn. You shouldn't be on asphalt anyways, and even if you was, the only thing you would be wearing out fast is your tires. Off-road, it's all good. Don't worry about it!
frostphase
Aug 23, 2015 07:36 PM
firsttimerider
3) General Discussions..
8
Aug 21, 2015 08:55 PM
DeFox500
Aug 14, 2015 05:59 PM
95wolv
Jul 17, 2015 08:13 PM
joeyupton
Jul 14, 2015 11:51 AM
