XP 850 Zerk fittings
Just a quick question about the grease fittings on the 850. They are standard size grease fittings aren't they? I bought a new grease gun, one of the half size ones so I can keep it on the quad. It was very tight to put on the grease fitting and I can't get the thing off. I actually had to unscrew it and leave the end on the machine so I could ride today. I couldn't even get it off with channel locks.
Take care,
Dave
Take care,
Dave
<div class="FTQUOTE"><begin quote>Originally posted by: eggenz7
sometimes new tips on grease guns really like to hold onto the grease fitting. if you grab the tip and move it so your trying ot make it into a 90 degree corner with the zerk it will usually let go</end quote></div>
Yes they do! And that works..just be careful not to force it to hard if it is really tight 95% of the time that works but I have seen fittings break and/or pull out the threads...
Another option is to use a flat tip screwdriver, put the edge inbetween the grease gun fitting and the zirk base/A-arm or whatever and give it a twist, or better yet I like to use needle nose pliers if you have some with a small enough point,grab the base of the zirk lightly and use it as a fulcrum to pry the fitting up and off...
