XP 850 Zerk fittings
Old Jan 25, 2009 | 10:31 PM
Daledo's Avatar
Default XP 850 Zerk fittings
..Book says after each pressure wash
I ride and wash about once a week and dont really feel it needs to be greased once a week.
How often do yall grease your fittings??
Old Jan 25, 2009 | 10:50 PM
600Grizzly's Avatar
Just a quick question about the grease fittings on the 850. They are standard size grease fittings aren't they? I bought a new grease gun, one of the half size ones so I can keep it on the quad. It was very tight to put on the grease fitting and I can't get the thing off. I actually had to unscrew it and leave the end on the machine so I could ride today. I couldn't even get it off with channel locks.
Take care,
Dave
Old Jan 26, 2009 | 05:31 AM
700 sportsman's Avatar
Did you try to take it off by pushing it off the side, and my 700 manual, says to grease bi annually, I usually do it when I change all my fluids
Old Jan 26, 2009 | 07:05 AM
eggenz7's Avatar
sometimes new tips on grease guns really like to hold onto the grease fitting. if you grab the tip and move it so your trying ot make it into a 90 degree corner with the zerk it will usually let go
Old Jan 26, 2009 | 08:20 AM
HIGHOCTANE's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: eggenz7
sometimes new tips on grease guns really like to hold onto the grease fitting. if you grab the tip and move it so your trying ot make it into a 90 degree corner with the zerk it will usually let go</end quote></div>
Yes they do! And that works..just be careful not to force it to hard if it is really tight 95% of the time that works but I have seen fittings break and/or pull out the threads...
Another option is to use a flat tip screwdriver, put the edge inbetween the grease gun fitting and the zirk base/A-arm or whatever and give it a twist, or better yet I like to use needle nose pliers if you have some with a small enough point,grab the base of the zirk lightly and use it as a fulcrum to pry the fitting up and off...
Old Jan 26, 2009 | 11:37 AM
Rutcutter's Avatar
I grease mine after every other ride,doesnt take any time at all and it push's all the water and crud out.. Those top a arm zerks are a pain in the azz to grease,I think im going to install some 90* zerks on mine.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
tysonbully
Sep 28, 2015 02:30 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
bigred20653
Sep 19, 2015 02:11 PM
