05 scrambler no start
Old Feb 6, 2009 | 09:02 PM
n283900's Avatar
Default 05 scrambler no start
2005 scrambler 500HO. Had it for little over a year, maintained. No upgrades.
Starter spins, doesn't turn engine over. Pull start will not move, not even a inch. Tires will not spin, no matter what postion the gear selector is in. Linkage from gear selector to transmission is still intact.
I was thinking, possible starter gear failure getting stuck between the housing, or the flexplate for the starter has broken.
Anyone else run into this kind of problem? Any advice would be helpful!
Old Feb 6, 2009 | 09:14 PM
ftwflh's Avatar
Pull the recoil over off and see what is hung up in your flywheel
Old Feb 7, 2009 | 10:39 AM
Kerbbirds's Avatar
pull ur clutch cover off, maybe ur belt shredded and is caught in the clutch
Old Feb 7, 2009 | 02:23 PM
ftwflh's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Kerbbirds
pull ur clutch cover off, maybe ur belt shredded and is caught in the clutch</end quote></div>
That is most likely what has happened
Old Feb 7, 2009 | 02:27 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i ws going to say it wouldnt matter if the engine woul;dnt turn over or not to have the tires move so either as you guys stated the belt stopping the secondary from turning or something broke in the trans. if he can move the gear selector between the forward/n/ reverse.
polaris scrambler00
Jun 20, 2015 08:49 AM
hoopduerr
Jun 10, 2015 03:00 PM
hoopduerr
Jun 2, 2015 09:01 AM
hoopduerr
Jun 1, 2015 08:22 PM
1000gade
May 27, 2015 12:37 PM
