500 sportsman cam???
Old Feb 9, 2009 | 12:14 AM
gaugedholes's Avatar
Default 500 sportsman cam???
i gotta replace my head gasket...and i got a 500 not the ho..... i have heard that the differance between the 500 and the 500ho is the cam and the head...anyone??? i guess i might have the head ported... and i need to find a 500ho cam or a hot cam stage 1....any one have a 500ho cam or any info where i can get either of those cams let me know...thanks..
Old Feb 9, 2009 | 05:53 AM
ftwflh's Avatar
What yr of Sportsman do you have?
Old Feb 9, 2009 | 10:44 AM
1997 sportsman 500
Old Feb 9, 2009 | 12:29 PM
Kerbbirds's Avatar
cam and carb is the difference, put HO cam in bolt right up and then a 40mm carb, like what comes off of the scrambler 500, that is the difference between the two
Old Feb 9, 2009 | 06:13 PM
user493's Avatar
Moto Psycho
I think the clutch needs new weights or a different spring when you change the carb and cam. Not 100% sure but I heard it was 3 C's - cam, carb, & clutch. Anyway, it gives you 15-20% more power so it feels more like a 600 when you hit the throttle. [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Feb 10, 2009 | 09:45 PM
is that it??
Old Feb 11, 2009 | 07:30 AM
Kerbbirds's Avatar
Yes, we have done this, makes quite a difference in power , getting the jetting right took a little while , I think it went from a 145 to a 150 main if I remember but that all depends on elevation, we still have the same spring, with a little lighter weights in clutch.
Old Feb 11, 2009 | 05:18 PM
ftwflh's Avatar
On 500s the clutching is the same on HOs as the non Hos ll the HO amounts to is a hotter cam and bigger carb.
If your carb is bad Aaen used to carry a upgrade cam and carb
Old Feb 11, 2009 | 08:06 PM
user493's Avatar
Moto Psycho
BTW, people were using Scrambler 500 parts to make Sportsman 500 H.O.s before Polaris made them.
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
