07 Sportsman Speedometer
Old Feb 9, 2009 | 08:39 PM
muddawg139's Avatar
Default 07 Sportsman Speedometer
My 2007 Sportsman 700 lost power to the speedometer and won't start. Engine turns over but won't fire. The 12v plug shorted out so that is disconnected. All fuses are intact and there is power to the harness. I'm at a dead end. Any help?
Old Feb 9, 2009 | 08:57 PM
Is there voltage on red wire into speedo head connector?
Old Feb 9, 2009 | 09:08 PM
muddawg139's Avatar
yes there is voltage to both the red ignition wire and the ETC
Old Feb 9, 2009 | 10:15 PM
<div class="FTQUOTE"><begin quote>Originally posted by: muddawg139
yes there is voltage to both the red ignition wire and the ETC</end quote></div>
What I meant is there 12 volts on the red wire in the harness that plugs directly into the speedometer!! Large connector with a bunch of wires. Should be power to wire at all times key off or on doesn't matter. If not may be the problem,or if has power, then speedo may be at fault.
Old Feb 10, 2009 | 07:11 AM
muddawg139's Avatar
Yes there is power there. I checked both pins and both are getting 12 volts +/-. Started right up this morning and now the speedometer is working. ???
Jmuddin284
Jan 19, 2026 07:16 AM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
79hugger
Aug 30, 2015 02:21 PM
400H0
10
Aug 20, 2015 07:34 PM
