Squeak in front end??? Any idea?
Old Feb 19, 2009 | 07:55 PM
GTSnoRacer's Avatar
Default Squeak in front end??? Any idea?
Anyone else have a squak in the front end of their Sportsman at low speeds?
I'm thinking something stuck between rotor and brake pad, but there's no grooves on rotor...yet [img]i/expressions/face-icon-small-sad.gif[/img] OR Bad wheel bearing? Seems to get louder/worsen with braking...Anyone else experienced this? Only ~50 hours and 300 miles on the machine, still under warranty if it matters.
New member here and I've read many topics in this forum, the members are knowledgable about their Polaris' and very helpful.
'07 SP500HO EFI Deluxe LE (in case sig. doesn't work)
Old Feb 19, 2009 | 08:08 PM
Have this complaint all the time! Probably a little dirt,corrosion on pads or rotor causing noise. Wash caliper are thoroughly,then spray ENTIRE caliper and rotor area with wd 40.Will remove rust and moisture.JUST dont try to go too fast and try to stop after use until parts are dry! Probably will stop noise. Happens a lot especially if going through water and mud.
Old Feb 19, 2009 | 08:11 PM
GTSnoRacer's Avatar
Thanks for the quick reply! Is there any problem riding with this for a short time until it's warm enough to wash the bike without freezing?
Old Feb 19, 2009 | 08:22 PM
No problem,JUST a little noise! May actually clear up on its own!
Old Feb 19, 2009 | 09:34 PM
upnort's Avatar
Had a squeak on one my other sp's, was the steering ball joints 4 total inside the rubber boot. Pulled boot open a bit ,sprayed with wd 40 & went b bye.
sara durrant
Jul 6, 2015 05:32 PM
traumajunkie
Jul 5, 2015 03:03 PM
D-Hagz
Jul 4, 2015 02:19 AM
Mphillips
Jul 2, 2015 07:20 PM
bikedad3
Jul 2, 2015 02:15 AM
