warrior wont rev up all the way.
my 87 warrior runs god other than when i ride it and open up throttle it wont rev up like it should. almost as if it was hitting rev limmiter. i was thinking carb problem but i cleaned it and it looks good so i'm back to sqaure one???? any ideas.
PARKING BRAKE SENsor??? i took off the parking brake a while ago and this problem just started, wheres the sensor?? when i ride the qaud it only gives me like half the rpm's as usual. the wheels turn fine. like i said earlyer it's almost like i'm hitting the rev limiter, or like it's governed at have throttle
As long as you connected the two wires on the sensor on the clutch perch you are fine there, but make sure they are still connected well and such. Check the governor screw on your thumb throttle, and lube your throttle cable.
yeh no wires at the levers, i'll check out the sensor if i can find it and loop them together.also have twist grip trottle with new cable, can't see that being the prob. thanks guys. i'll try it, any othe suggestions
Steeldon
Sep 9, 2015 09:38 AM
