warrior wont rev up all the way.
Old Feb 23, 2009 | 11:10 AM
dee-stroyer's Avatar
Default warrior wont rev up all the way.
my 87 warrior runs god other than when i ride it and open up throttle it wont rev up like it should. almost as if it was hitting rev limmiter. i was thinking carb problem but i cleaned it and it looks good so i'm back to sqaure one???? any ideas.
Old Feb 23, 2009 | 11:23 AM
beefy46172's Avatar
Loves To Ride!
Check your parking brake sensor. What do you mean by not rev up? Just pops and what not, or revs but the wheels don't seem to go faster?
Old Feb 23, 2009 | 12:47 PM
PARKING BRAKE SENsor??? i took off the parking brake a while ago and this problem just started, wheres the sensor?? when i ride the qaud it only gives me like half the rpm's as usual. the wheels turn fine. like i said earlyer it's almost like i'm hitting the rev limiter, or like it's governed at have throttle
Old Feb 23, 2009 | 01:17 PM
beefy46172's Avatar
Loves To Ride!
As long as you connected the two wires on the sensor on the clutch perch you are fine there, but make sure they are still connected well and such. Check the governor screw on your thumb throttle, and lube your throttle cable.
Old Feb 23, 2009 | 01:19 PM
ATV_MAN's Avatar
yes since you don't have the parking brake anymore it's a good idea to eliminate it, there should be some wires up near your handlebars that go to a switch on the left brake lever.
Old Feb 23, 2009 | 02:26 PM
yeh no wires at the levers, i'll check out the sensor if i can find it and loop them together.also have twist grip trottle with new cable, can't see that being the prob. thanks guys. i'll try it, any othe suggestions
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
Steeldon
Sep 9, 2015 09:38 AM
toonces
Sep 5, 2015 01:14 PM
