ECM, PDM, Sure power module, controller module
Old Feb 24, 2009 | 09:59 AM
94harley's Avatar
Default ECM, PDM, Sure power module, controller module
I have two machines in the shop now that need new ECM's. 2007's. Since they are now paper weights I thought I'd tear one apart and see if i could find a burned spot, broken wire, burned connections or resistor, whatever, etc. One of them didn't have(guessing) 400 miles on it. So I thought I'd take a couple pics and post them. Prolly won't help anybody with anything but oh well, here they are(if I do this right)
One of the bad ecm's would keep the fan running constantly(key on) and the other one wouldn't give any electrical to the machine at all. I poked around with an ohmmeter trying to see if I could find anything that tests different between the two but didn't. To many little diodes, resistors etc to check.
Old Feb 24, 2009 | 05:33 PM
eggenz7's Avatar
the black stuff on the blue cap is it insulation from the circuitry under it or did it leak out?
if i were to put money on whats wrong with the thing i would say its one of those transistors on the side.
Old Feb 24, 2009 | 07:42 PM
94harley's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: eggenz7
if i were to put money on whats wrong with the thing i would say its one of those transistors on the side.</end quote></div>
I figured the same thing, but testing and comparing them, they all tested the same between the 2(which had different failures so I figured if it was those, the corresponding ones would test different). I was going to unsolder the bad one(if I found one) and try to fix the other one but that didn't seem to be it. The black stuff looked more like an insulation/vibration dampner maybe.
Old Feb 24, 2009 | 08:55 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
That's just glue holding it in place,But I am on my third one..........Is this the one made in China/
Or the one made in the U.S.A.?
Black one =china
Silver one =U.S.A
Question if it was done under warrenty ......They asked me for the return of both of mine!!
Didn't you need to give it back ?
Caper..............
2quiker
Mar 22, 2022 08:36 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Logan Collins
Sep 5, 2015 08:03 PM
toonces
Sep 5, 2015 01:14 PM
Pahuntman
Sep 5, 2015 11:07 AM
