Mismatched tire size on 2001 Fourtrax 4x4
Old Feb 27, 2009 | 08:38 PM
Dougjm's Avatar
Default Mismatched tire size on 2001 Fourtrax 4x4
I just noticed that my local dealer put two different size tires on the back of my 2001 Fourtrax 350ES 4x4. The left one is a 25x10-11 Mudlite and the right one is a 24x9-11 Mudlite. I haven't used the quad for any great distance, probably 10 miles. I suspect that the different sized tires may cause damage - anyone know how severe this could be?
Old Feb 27, 2009 | 09:05 PM
JeffinTD's Avatar
Welcome to the forum.
Having a solid rear axle, I doubt it did any damage, but I'd be for going back to the dealer to make it right ASAP.
Old Feb 27, 2009 | 10:31 PM
snorulz's Avatar
the only thing it should do is wear one tire out fast and make the machine pull to one side. Have the dealer fix the problem ASAP as JeffinTD already stated.
Old Feb 28, 2009 | 05:36 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Got to watch those dealers every move!!!
The larger tire will give a higher effective gearing than the smaller, so it will pull toward the side with the smaller one...but it shouldn't do any "damage".
Old Feb 28, 2009 | 05:46 AM
gambler_m_99's Avatar
I would just have to ask the dealer what he was thinking. Did he charge the same price on each tire?
Old Mar 1, 2009 | 08:33 AM
Outof$'s Avatar
The only way that would make sense is if your front two had the same problem. One 25 and one 24. Other then that your dealer screwed up! Take it back and get it fixed, then have him sell that tire to you REAL cheap for replacement for the front.
Old Mar 1, 2009 | 09:59 AM
SS420's Avatar
Make sure they go to the correct size whether it is 24 or 25 which ever tire they replace. If it is supose to be 25 and they put 24" or vi versa you will have issues when you put it in 4wheel drive. enless your bike does its gear reduction for differenent size tires front and back in the tranfercase, make sure they are the same size. 24"up front and 24" out back. Or 25" up front and 25" back. On my 420 I went fron 24" all the way around to 25" all the way. Just wish I had done it sooner. Love the extra ground clearance.
Bratman2
Aug 6, 2022 01:42 AM
ScopeZ_
Jul 28, 2015 01:44 AM
rcappie4
Jul 18, 2015 07:51 AM
maxjung
Jul 14, 2015 03:10 AM
