94 4x4 400L AWD problem in H
Old Feb 27, 2009 | 09:08 PM
mywingnuts's Avatar
Default 94 4x4 400L AWD problem in H
Hey Guys,
I recently replaced left hub strut on my 94 Sportsman. My current problem is when the AWD switch is pressed the AWD light randomly turns on and off while in High. When it is shifted to low the AWD light stays constantly lit. I had burnt oil and metal grindings in the old hub before I replaced the strut, should I replace the bearings and hub also? Would messed up bearings cause this?
Thanks in advance!
Old Feb 27, 2009 | 10:06 PM
Wear in shifter box internals and switch common problem when in hi range and awd on on the 94 model! Usually works good in low range which is not used as often! Strut work would have no effect on this.
Old Feb 27, 2009 | 10:18 PM
mywingnuts's Avatar
Looks like I will be looking for a new shifter switch.
Thanks!!!!
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
