pirmary clutch wear
Old Mar 3, 2009 | 09:50 PM
albertaborn's Avatar
Default pirmary clutch wear
how much play should be between the primary stemless button and the spider? Also its seem as though one of the holes in the spider where the button sits looks worn outwards like i can move the button around pretty good but only on the one button the rest stay put not bad but spider still loose. i fear i need a new spider and some buttons may as well be a whole clutch 2003 scrambler 500
Old Mar 4, 2009 | 06:08 AM
ftwflh's Avatar
Look on the slide tower for grooves worn in from buttons.Not a good idea to change parts on these clutches but can be done.They are balanced as a unit.
Old Mar 4, 2009 | 06:49 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
they become noisy when they were out as well.
Old Mar 9, 2009 | 05:39 PM
theres a little wear on the towers and between the buttons and the tower theres a couple mm play but my concern is how the button would be contersunk into the spider one of the countersunk hole is warn out letting the button move around alot it happens to be on the x spider just on one side
Old Mar 9, 2009 | 09:22 PM
ftwflh's Avatar
Best to get it taken apart and checked out
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
