Need some advice
Old Mar 5, 2009 | 11:42 AM
Bulldog1118's Avatar
Default Need some advice
05 Grizzly
When trying to start I would hear a clicking/grinding sound in battery area before quad would finally start. I replaced the battery and it seemed to help for a while, then it completely quite. It would click/grind and never would start, had to pull start only. Replaced starter relay - didn't work, replaced starter motor - didn't work. My arm is getting a little worn out from pull starting so any advice would be appreciatd. Thanks
Old Mar 5, 2009 | 12:28 PM
muddyweekends's Avatar
my griz i had a bad starter, it would click by the relay..get a volt meter see if your voltage when atrating it at the strater boos ..let me know
Old Mar 5, 2009 | 01:22 PM
DaveD912's Avatar
Perhaps the charging system isn't working? That would explain why a new battery only helped for a while.
Old Mar 6, 2009 | 07:36 AM
JLsparky7's Avatar
Do you run a trickle charger when your not riding?
Old Mar 6, 2009 | 08:57 AM
No, I don't run one. Should I be?
What is all part of the charging system? Just the rectifier and magneto? The clicking sounds seem to be right in the area of the rectifier. That is why I had assumed it was the starter relay when it had first quite working.
Old Mar 6, 2009 | 09:34 AM
kevinwbaker's Avatar
Harbor Freight tools offer a nice solar powered trickle charger. I connect it to my atv, ran it out the garage to the roof...it's a night little thing to have. The only issue is I had to splice the wire so I could run it a good length. I think it came with like a 10 ft wire.
Old Mar 8, 2009 | 11:11 PM
UGLY88's Avatar
your starter is probably going bad. I had it happen on my older Wolverine. Bad battery then bad starter. I bought a starter rebuild kit online that was rather inexpensive, and rebuilt mine. But check the volts at the battery when running, I believe it should read, 13.5 to 15.7 or something like that?
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
