can bad reeds cause low cylinder compression?
Old Mar 13, 2009 | 10:42 AM
TimberedWolf250's Avatar
Default can bad reeds cause low cylinder compression?
just want to know if bad reeds or crankcase leak can cause low cylinder compression? I have been told yes and then was told No need another opinion and why or how ?
I am only getting 35 psi when using kickstart this is on a 90 blaster yfs200
2 stroke
thanks
or are the rings bad, I did pull the head piston looks great cylinder wall smooth
Old Mar 13, 2009 | 02:31 PM
hardluckhenry's Avatar
i say the rings is your problem
Old Mar 13, 2009 | 03:14 PM
Raptor450's Avatar
I would guess the reeds could cause low compression. The piston sucks the reeds open on the upward stroke(compression) after the piston passes by the intake port, so if the reeds are leaking until the piston gets past the port, it would cause it to not build as much compression. If you pulled the head, why not go ahead and pull the reeds?Usually if you can see light thru the gap, they need replacing.
Old Mar 13, 2009 | 07:58 PM
Thanks all
I am going to replace rings and reeds
Dewhound
Apr 20, 2017 02:25 PM
QuadRiders
Oct 22, 2015 04:13 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Jaymc
Sep 11, 2015 07:45 AM
Jason Richards
Sep 4, 2015 06:17 PM
