Front end problem
Old Mar 15, 2009 | 05:44 PM
habsfan's Avatar
Default Front end problem
When I push down on the right side of my front end I am getting a knocking sound around the right wheel. I don't think it's the shock. I am not sure how to diagnose this type of problem. Any info would be appreciated.
Old Mar 15, 2009 | 08:03 PM
trailbuzzer's Avatar
Habsfan
What model atv? How many miles are on it?
If you can find someone to help you, have them push down while your looking down below.
Also see if you can support it off the tires and wiggle up and down each tire/wheel to see if its more noticable while suspended
Old Mar 16, 2009 | 06:08 AM
gambler_m_99's Avatar
Is it 2 wheel drive or 4. Sounds like it is the wheel bearing if it is 2 wheel drive.
Old Mar 16, 2009 | 04:19 PM
habsfan's Avatar
It is a 2001 Honda 350 es with 4000 miles. When I suspend it and wiggle the tire it feels loose
Old Mar 16, 2009 | 04:36 PM
Habsfan
I would suppose your due for a bushing replacement.
Old Mar 16, 2009 | 05:17 PM
Gimpster's Avatar
If it is loose, the wheel bearing is most likely bad
It is a double bearing
Hopefully it has not wollered out the spindle where the outer part of the bearing rests
----- Gimpster -----
WilliamBos
Sep 30, 2015 08:08 AM
Stillonit
Aug 5, 2015 07:46 PM
scaldwellk
Jun 19, 2015 05:08 PM
blaze_master
May 26, 2015 11:18 AM
