Starter problems 99 450trx foreman
Old Mar 16, 2009 | 08:28 AM
CE450's Avatar
Default Starter problems 99 450trx foreman
Will start fine sometimes but other times you can push the starter button and the relay will click but the starter does nothing. When it does this I can put it in reverse, rock the bike back and forth put it back to neutral and it will start right up.
Old Mar 16, 2009 | 09:31 AM
MEGA XP's Avatar
Sounds like the nuetral start switch.
Old Mar 16, 2009 | 05:24 PM
Gimpster's Avatar
Next time it does it, take a small hammer or cresent wrench, tap on the starter while depressing the starter button and see if it will turn over
Most likely it needs starter brushes which is the case if it turns over while doing the above test.
It's the most common problem with honda starters
----- Gimpster -----
Old Mar 18, 2009 | 11:47 AM
CE450's Avatar
Thanks Gimpster, went home and tried that last night and it cranked right up. Nice to know its a small problem to fix.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
tweeder
Jul 5, 2015 01:57 PM
