mechanical problem
Old Mar 21, 2009 | 11:43 AM
sparkdawg's Avatar
Default mechanical problem
Ibought a chinese quad about seven weeks ago and it wont start after sitting more than a day i bought a new battery for it to get it started after assembly because the battery they sent with it would not even turn quad over. It will start every time if I charge the battery. After it sits for a day it wont start without a charge???? Not sure what is going on? Any suggestions please.
Old Mar 21, 2009 | 12:12 PM
LynnEdwards's Avatar
Electrical Expert
Two things you need to check:
1) When the quad is off and sitting, is anything drawing current from the battery and running it down? To check this remove the the main fuse and insert a current meter in the fuse's place (across the fuse terminals) on the 10 amp DC scale. You should see zero current flow. Remember that on most meters you have to set the voltmeter switch to DC current and also move the red lead to the 10 amp current input jack.
2) With a charged battery and the quad started up, measure the battery voltage right on the battery terminals. It should read 14 to 14.5 volts when running at a fast idle and headlights turned off. If it reads 12.6 volts or below then your charging system is not working.
Don't have a meter? These work fine. I have several. You really do need a meter when troubleshooting electrical problems:
Harbor Freight Voltmeter
Once we know whether the charging system isn't working, or if something is draining the battery we can go from there.
Lynn Edwards
Old Mar 21, 2009 | 12:17 PM
Scalerman's Avatar
hey sparkdawg
Bought my 250 chinese geo quad in July of 08. The electrical in these are very cheap.
Your description sound like the battery is draining out through a ground or short somewhere.
I had two problem areas on mine, Where the cables come through to the battery under the seat.
The sharp plastic edges cut through the wires. (2) The fuel tank was setting on my reverse light cable and
wore the wires bare to the frame.
I would suggest that you closely examine all your connections and then the wires for wear against the frame.
If you still cannot find the problem, then taking off your fenders and body will be a PITA but you will
be able to check your wiring thoroughly.
hope the helps
Old Mar 21, 2009 | 12:28 PM
sparkdawg's Avatar
Thanks for your suggestions ill give it a shot
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
greg74
Sep 10, 2019 03:03 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
