08' 400 lessoned learned
well figured i would share my stupidity. well the 400 being down back w/ a dead battery(and i still cant move good ,so i cant hand crank it) i had made up a set of wires to use a an alt. charging way off the wire harness they have under the storage panel. anyways w/ my stored car beside it(w/ the car not running) i hooked cables up to the wires and it light up the lights good for about a second and couldnt get it to run power thur it. long story short(i know too late)there is a fuse down inside on the wire harness that is a 3 amp fuse and when i hooked up a car battery(wheeler batteries are only like 14 amp) it blw that fuse instantanly. more is dont ever try to put more then a 2 amp charger 2 that pigtial or you'll have the same issue. just a fyI for people who have these.
this is why i keep preaching about not jumping machines(not just wheelers) w/ autos w/ 100 amp alt. or anything high out put into a system that can handle like the batteries thats in it which is like a 14 amp. a good comparsion is the next time you look at your battery say in your truck and then at your wheeler, noticed the HUGE differnce in the size of the battery cables. the larger the cable the more juice it can carry. thants why most rec. vechicles ay only to charge w/ a 2 amp charger over 8 to 10 hrs as the batteries are only 14 amp to begin w/ and over ampage can do some damage to the whole system not justthe battery. just by own .02
ps btw, i put a 5 amp fuse back in and then got it to my batt. charger and got it charged on 2 amp the rest of the day and its good to go for the owner. lol.
Mar 22, 2016 09:55 AM
