clutch cover
Old Apr 9, 2009 | 06:19 PM
CHADDER700's Avatar
Default clutch cover
is there any trick to getting the clutch cover off of my 04 sportsman. well the cover itself looks easy enough but the plastics around it ie: the foot well and the fender. do they have to be removed or......???
thanks in advance
chad
Old Apr 9, 2009 | 07:34 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
its really basic if you look at it as far as the bolts that hold the foot well on and either screws or just push plastic butons that hold the plastic together. as far as the cover, just take off all the screws, just make sure that they are the same size and if there is a longer one that you put it back in the right hole. i think its either a 3/8" or 10mm socket and extentions and your good to go. oh yea dont forget to unhook the clamp that holds the cover vent on that goes up by the tank.
Old Apr 9, 2009 | 07:44 PM
Kerbbirds's Avatar
unbolt the footwells 4 bolts, remove the bolt under the seat on that side and you can pull the footwell and plastic out enough to get the cover off and by the plastic.
Old Apr 10, 2009 | 05:45 PM
CHADDER700's Avatar
thanks for the help guys, thats what i thought... i got it all apart without a problem. does anyone know which models have the lifetime warranty belts?
Old Apr 10, 2009 | 05:55 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
pretty much the newer bikes 06' area but its pretty much a waste of time as they'll say it was driver error but i could be wrong.
fordfaithful21
Dec 7, 2015 05:52 PM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
cdstang
Aug 31, 2015 07:52 AM
