Idle problems
Old Apr 13, 2009 | 07:04 PM
Pakman's Avatar
Default Idle problems
I have a 94' 300 2x4, and once I get her started (on choke) then let her off of choke she will start reving up until I put the choke back on. What can I check to calm her down after I take off the choke?
Old Apr 13, 2009 | 07:24 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
sounds like you have an air leak, or check the cable to make sure its not adjusted too high like pulling the throttle and the idle adjustment is not too high.
Old May 8, 2009 | 01:19 AM
Pakman's Avatar
I also seem to have a problem with it idling after she warms up. It doesn't matter if I am in gear or not, but if I don't keep on the throttle the rig will die. Then one pull on the cord and she is running again. < what could cause this?
Old May 8, 2009 | 04:51 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i still would try to rule out an air leak. have you taken the carb apaprt to clean it? have you changed the air settings?
Old May 8, 2009 | 11:48 PM
Pakman's Avatar
I have taken the carb out and apart. I can only discribe it as "Mint". Does anyone know what the factory setting might be for the carb screws? I have yet to find it online and I don't have a book either.
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
MNatv89
Jul 7, 2015 11:36 AM
