03 sportsman 600
Hello, I am trying to change my front axles. I got the right one out, but can't get the left one to budge. I seen in another post that if you get one side you can knock the other out from the inside. This is not the case with mine. Any help would be greatly appreciated.
Thanks,
Justin
Thanks,
Justin
I've done mine and I have had good and bad luck. I have always used lots of spray lube and let it sit for days. Keep spraying and pulling the axle to help get the lube in the spindle part of the axle. Try to pull with a quick jerk to loosen the circlip. Just a quick question why are you replacing the axles?? Are they damaged??
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
cdstang
Aug 31, 2015 07:52 AM
