How to set clutch to 2-2 ?
Old Apr 15, 2009 | 10:28 PM
Pullarse500's Avatar
Default How to set clutch to 2-2 ?
Did I read something wrong or is it true that you can simply adjust the spring for higher engagement? If so, how?
This question is unrelated but does K&N make a stage 2&3 kit for a 01 Scram? THANKS
Old Apr 16, 2009 | 06:00 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
changing the place of which hole the spring goes into the on the secondary helix is how you change out shift rate such as 2-2, but if you want a higher engagement then you need a differnt primary(front clutch) spring.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
