LT80 Clutch belt widths
Old Apr 16, 2009 | 07:07 PM
Bowls's Avatar
Default LT80 Clutch belt widths
I've been reading posts and came across one that listed a 1 - 1.5 mm thinner belt. This would give more bottom end as it would sit lower in the pulley, correct me if I'm wrong. Do you lose any top end by going to the thinner belt. Also, where do you get these thinner belts? Anyone have a parts source or part number? Is this one of those Kragen moments where you just keep checking everything they have in stock?
Old Apr 17, 2009 | 07:57 AM
LT80's Avatar
LT80 Expert
I've never used anything other than the stock belt.
I don't think it'll make any difference in botom end.
There are better fixxes for bottom end.
Old Apr 22, 2009 | 12:56 PM
Buffw/4boys's Avatar
Default Lt80
i just got an lt80 myself for my 8 year old. went through the entire bike and put on a new stock belt. one thing i did was take out 3 of the rollers in the variator clutch. gets the rpm's higher and no lugging in low end. it rips now.
Old Apr 22, 2009 | 06:53 PM
onebigzj's Avatar
cut the rear shoes and shave the head and you wount belive it.
Old Apr 23, 2009 | 08:23 AM
LT80's Avatar
LT80 Expert
3 rollers isn't enough, 4 is better. You'll loose top end w/only 3.
Old Apr 23, 2009 | 02:25 PM
i took 3 out because leaving 4 in looked like it would be off balance due to the way the roller guides were formed. so leave 4 in the variator?
Old Apr 23, 2009 | 02:39 PM
onebigzj's Avatar
ya take 2 out. one from each side. will do wounders
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
