1983 Honda ATC110 Noise/Knock in neutral but not in gear
Hi all,
I'm new to ATC repair, and bought this 3 wheeler about 5 years ago. It needed the carb gone through, but was otherwise in good shape. It has been a good runner since I bought it. Last fall I started hearing a knocking noise on the right side - I believe in the clutch area when it is in neutral. When I put it in gear the noise is gone. I changed oil and saw no improvement in the noise. I also adjusted the clutch per the manual. Any suggestions would be appreciated. My daughter is ready to ride and getting tired of hearing, "not until I fix it" !
Thank you,
AJ
Thank you,
AJ
