2005 EFI 500 Sportsman
Old Apr 26, 2009 | 09:50 PM
jsully's Avatar
Default 2005 EFI 500 Sportsman
I know this is not a new problem- I could not find my answer searching old threads.
My 500 efi quit the other day, low mileage, (not exposed to any moisture- southern AZ), the fuel pump does NOT start when I turn the key on. Is there something else to troubleshoot before I replace the fuel pump & tank? Is there a fuse?
Any help will be appreciated - I am lost on this thing.
Thanks
Old Apr 26, 2009 | 11:21 PM
eggenz7's Avatar
you can get a replacement fuel pump from napa...do a search on here and the part number will come up...much cheaper than the whole tank assembly polaris wants you to buy.
have you checked for spark while turning the motor over? air filter in good condition.
you could take a test light and start tracing wires from the fuel pump to wherever they end up to see if power is still there.
Old Apr 27, 2009 | 05:30 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if this is an efi then there should be a fuse or circuit breaker for the fuel pimp. make sure you test it for power before you go to replace it. here is the post for the fuel pump.
forums.atvconnection.com/polaris/275063-aftermarket-part-numbers-800-efi-fuel-pump.html
Old May 2, 2009 | 10:19 AM
jsully's Avatar
I appreciate the repies and info.
I will be checking for power / fuses today.
Thanks
Jmuddin284
Jan 19, 2026 07:16 AM
txpedsrt1
Feb 3, 2017 08:07 PM
Shifts
14
Jul 13, 2015 08:41 AM
tporath
Jul 11, 2015 12:31 PM
Shifts
Jul 3, 2015 07:59 AM
