Warrior Air-Box
Old May 5, 2009 | 06:08 PM
KYDRIVER_1's Avatar
Default Warrior Air-Box
Sorry for so many questions and so few answers. The problem I have is that I can't get the lid off of my air-box. The threaded bushings or whatever they are in the bottom part of the box are just turning in place. So I can't back the bolts out. Is there anything I can do or will I have to get a new air-box? I really need to clean and oil my filter. Also would I be better off to get a new box or an externally mounted filter.
Again Thanks for any help.
Old May 5, 2009 | 09:44 PM
free2blaze's Avatar
Question
I dont know what to say to help get those bolts out, it would kinda suck to have to buy a new air box just because of those stuborn bolts, if your current one is in good shape,
maybe try to drill those blot heads out or cut em off ??? I believe if you installed just an air filter without the air box you would have to rejet the carb, good luck.
Old May 5, 2009 | 09:47 PM
beefy46172's Avatar
Loves To Ride!
You can always drill the bolts out or just break the lid off in order to remove the screws with other tools. A lid isn't so bad to replace. I wouldn't get a new box for better filtering, get the K&N Pro Design clampon intake and it will work in the same airbox but provide a solid clamp on filter.
Old May 5, 2009 | 10:00 PM
KYDRIVER_1's Avatar
I may just take a Sawzall and cut the heads off the bolts and put my own in. I didn't even think about doing that.
Thanks for the help guys.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
