05 sportsman 500 EFI Issue
Old May 6, 2009 | 02:27 PM
dre900's Avatar
Default 05 sportsman 500 EFI Issue
six months after I bought this bike I have been having trouble to keep the bike running. When the bike warms up it does not want to idle and it back fires. I brought it to the dealer and they replaced the spark plugs and re-adjusted the idle worked great until I got the bike good and hot again and it started again. The wierd part is that it start off as a little problem and the more times I use the bike it gets worse, like right now I cant even ride it it is so bad. I then had done some research myself and was told that it was the MAP sensor. Cool spent a $100.00 bucks and replaced it bike worked like new!! (was very happy) UNTIL I went for a good long right and made the bike work pretty hard I got one big backfire and that was it same old crap over again.
They were saying that polaris hade revamped the MAP sensor because if this issue but the sensor I got looked identical to the one I pulled out same numbers on it and all.
Please does anyone have any answers to this or have been through this.
Thank you
Old May 7, 2009 | 08:19 PM
Thank you
Usually not the sensors that go out,just the harness wires to the sensors. Repair kits are available
Old May 8, 2009 | 04:11 AM
helmethair78's Avatar
Is you check engine light on, if so what codes does it give you?
Old May 8, 2009 | 09:24 AM
dre900's Avatar
no I dont have a check engine light on
Old May 8, 2009 | 09:54 PM
Lot of times it WONT show a code when wire in a harness is faulty! It will just run good sometimes and crappy at other times. Dont have the numbers in front of me but I think # 2876315 for the sensor repair kit. I ought to know it by heart by now,but I dont!
Old May 9, 2009 | 05:29 PM
I just replaced the harness. I think the numer is 2875542, But the dearler will know for sure.
Jmuddin284
Jan 19, 2026 07:16 AM
skinnyr6
Aug 25, 2023 02:18 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Shifts
Jul 3, 2015 07:59 AM
