87 warrior has no air box top?
Old May 16, 2009 | 06:52 AM
87warriorpgh's Avatar
Default 87 warrior has no air box top?
Hello, when I bought the warrior it had no top to the air box. Looks to be a k&n filter in it. Can you run without this? Or would it run better with one?
Old May 16, 2009 | 07:13 PM
KYDRIVER_1's Avatar
If you are getting the right air/ fuel ratio and no unfiltered air is getting in you should be fine.
Old May 16, 2009 | 07:28 PM
91Warrior357's Avatar
is it just a drop in k&n? if so then i wouldnt run it with the lid off, since the lid is designed to hold the filter in place and there is like a 2 inch gap from the filter to the intake boot alot of dust will go directly into the carb, if its a clamp on filter then you should be fine, im guessing somebody should have already rejetted for that setup, as long as it doesnt hick up real bad when giving alot of throttle u should be fine, just clean and oil the filter every once in a while they get dirty pretty fast with no lid.
Old May 16, 2009 | 09:24 PM
Scooter86's Avatar
Knows Old ATV Questions!
I prefer to have a lid. more protection for that motor, rebuilds can get spendy in a hurry.
Old May 18, 2009 | 08:35 AM
Swerve's Avatar
Yea if you have the right filter and jets it should be fine to run like that. The only other thing is just to be careful and not be going througha bunch of mud and dirt and water. With that open box it's a lot more likely to suck somthing into your motor.
Old May 18, 2009 | 11:13 PM
ebmoney08's Avatar
he is a lid i found on ebay... you wouldnt have to worry about it then
Warrior YFM350 YFM 350 Airbox Air Box Lid Cover Cap New:eBay Motors (item 220394366612 end time Jun-10-09 12:47:15 PDT)
-Eric
Old May 19, 2009 | 03:57 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
Make sure it's a clamp on as stated above. Then I'd get a pre-filter. K&N themselves recommend pre-filters.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
