87 warrior has no air box top?
is it just a drop in k&n? if so then i wouldnt run it with the lid off, since the lid is designed to hold the filter in place and there is like a 2 inch gap from the filter to the intake boot alot of dust will go directly into the carb, if its a clamp on filter then you should be fine, im guessing somebody should have already rejetted for that setup, as long as it doesnt hick up real bad when giving alot of throttle u should be fine, just clean and oil the filter every once in a while they get dirty pretty fast with no lid.
he is a lid i found on ebay... you wouldnt have to worry about it then
Warrior YFM350 YFM 350 Airbox Air Box Lid Cover Cap New:eBay Motors (item 220394366612 end time Jun-10-09 12:47:15 PDT)
-Eric
-Eric
