Transmission noise/ loose sprocket
Old Jun 2, 2009 | 06:04 PM
pastorclay's Avatar
Default Transmission noise/ loose sprocket
Recently purchased a 2003 Trail Boss 330. I have noticed a popping/ knocking sound that seems to come from the transmission area. I have noticed that the front sprocket has some play in it. Anyone seen this or know what the problem is? Thanks.
Old Jun 2, 2009 | 06:50 PM
400x's Avatar
Scared to death of girls!
It could be a worn sprocket, a bad link in the chain, or even a loose chain that is skipping over the sprocket. I've had all three things occur. I'd recommend getting the back tires off the ground safely, and running it while you watch that area.
That'd be a good start, IMO..
Old Jun 2, 2009 | 07:59 PM
pastorclay's Avatar
Thanks, 400x. I got it off the ground, but it doesnt make the noise.I guess not enough tension without the weight of the rider. I was leaning towards sprocket (at least hoping not transmission). Anyway, a good place to start.
Old Jun 2, 2009 | 10:28 PM
DaKeith's Avatar
i have a 96 425 magnum and i had a similar noise coming from my transmission and it was the sprocket for the rear chain. the way i knew right off it was the sprocket was that i looked at the chain where the sprocket was and could not see no teeth on the sprocket, they where worn down that much.
Old Jun 3, 2009 | 07:31 AM
Kerbbirds's Avatar
If you replace sprockets you ned to replace chain also, old chain will wear out new sprockets.
Old Jun 4, 2009 | 09:17 PM
pastorclay's Avatar
Thumbs up
Front sprocket appears to be the cause. Thanks you guys for the help.
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
buddieboy
Dec 9, 2016 05:50 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
