Black oil in exhaust
Hey Gang,
I recently purchased a 2007 Grizzly 660 in need of repair, but it has been a real beating. Need a bit of diagnostic help.
It is spitting out a bunch of oil. Where the muffler and head pipe connect, oil steadily drips. Here is what I have replaced so far.
New timing chain
New valve, springs, retainers
New piston rings, yes I offset the ring gaps. Of course gaskets and oil change.
The piston and cylinder jug were in spec so I didn't replace or bore them.
The cylinder head looked good so I thought maybe just some new valves. The center intake valve was bent due to it jumping time. When I put it back together. I checked valve lash 3 separate times before starting. Almost immediately it was smoking and then spitting oil.
What do you think, take the head off and get a 3angle valve job? What do you think is allowing so much oil to pass into the exhaust.
Thanks,
Trent
New timing chain
Thanks,
Trent
It could be many. many things.
Here is a short list for you:
#1 Broken ring/s.
#2 Bore and or piston out of spec.
#3 Valve guide seals missing or screwed up.
#4 Sump over filled with oil.
#5 Rings installed upsidedown or in wrong position.
#6 Incorrect or blocked sump vent.
If nothing weird is wrong, I think you have ring problems. This is the only way that I have seen an engine pump the amount of oil your talking about.
Do a leakdown. I would be a beer you have a hurricane coming out of the breather.
#1 Broken ring/s.
fordfaithful21
Dec 7, 2015 05:52 PM
