clankity clank on 550 xp
i have a 550 xp with about 200 miles on, and on my right back side of the quad is making a clanking sound, its really noticeable when im turning right. im thinking it could be my brakes but my brakes are tight, so im thinking it could by my cv joints. would anybody else have any ideas. its my second issue i have to fix.
im going to tie up my brake caliper and turn right and see if it does it.
no it isnt under warranty. thats the bad part. but what i did was switch drive shafts at the rear from left to right. and clanking isnt there anymore. if it is its very slight. becasue i wanted to eliminate the cv joint to see of the sound was still from the right side. its not there anymore.
FWIW - my dealer replaced BOTH rear axles for noise issues. I had 500 miles or so at the time. MrsBMQ's 850 doesn't make any noise - yet - after 350 miles. Mine started when the quad got to almost 500 miles.
i had put the lock nuts back on and retorqued everything. since warranty is off i didnt want to replace something that i shouldnt have. i will leave it for now. its 99% better. i had replaced all my oils. and what a pain in the **** to replace the filter. what do you guys do.
ive been driving my 550 xp for a while now, with only 200 miles on it. there is now a high pitch whine and howl, coming from the back at around 30 miles a hour... so i then checked the cv joints and come to realize that both inner and outer cv joints at the rear where so hot i could not touch them, and that the paint was completely gone. i then touched the front cv joints and they were all cool as a cucumber.
so now i have to replace all the cv joints at the back. with no warranty its going to be pretty costly.
SGT
Oct 8, 2001 03:44 PM
